It is currently Fri Jul 25, 2025 4:54 am
PostPosted: Tue Mar 15, 2005 5:32 am
When I went to the shop this morning to work on a guitar, I discovered the top had seperated along the glue joint from the base of the guitar to the bridge plate. I tried to clamp it but it wont budge because to crosses the lower transverse brace. The guitar is assembled and almost ready to finish. Any help would be appreciated.
PostPosted: Tue Mar 15, 2005 5:51 am
Rick, slowly hydrate the guitar to close the gap. Then reglue with appropriate glue. I use hot hide glue and sometimes Titebond.
Hydrating doesn't mean a trip in the shower. Put it in a RH room at the level you want, even a guitar case with Dampits, soundhole humidifier, Kyser makes one. Or a sponge on a plastic lid, taking care not to let moist sponge come in contact with the guitar body.
Sorry for your troubles, it's not the end of the world. Good luck.
Sounds like you had an adjustment in the RH factor overnight, or at least since the top was attached. You might try to increase you humidity a little and see if it closes.
PostPosted: Tue Mar 15, 2005 5:54 am
Sounds like you had a contaminated area in the joint or maybe had a big RH swing in the shop. You can build a screw jack to go inside to bring the plates back to level with each other. I believe Frank Ford has an article on this at his sight. (frets.com)
PostPosted: Tue Mar 15, 2005 6:50 am
here it is
PostPosted: Tue Mar 15, 2005 7:01 am
thanks all I'll let you know how it comes out.
PostPosted: Tue Mar 15, 2005 7:36 am
First name: Josh
Last Name: French
City: Houston
Rick, what kind of glue did you use?
Instagram: @jfrenchluthier
